ecu
Old May 19, 2010 | 08:34 PM
GSR615's Avatar
Default ecu
dumb question but are p61 and p72 the same ? they are both obd1 and for gsr
Old May 19, 2010 | 09:01 PM
GSR615's Avatar
Default Re: ecu
anybody ?
Old May 19, 2010 | 09:47 PM
mtber's Avatar
Default Re: ecu
No they are not the same. A p61 is for a b17 which isn't the same as a b18c1.
The p61 will run a b18c1 engine, but it isn't mapped for it.
Old May 20, 2010 | 04:22 AM
97Preludeguy's Avatar
Default Re: ecu
If I remember correctly the P61 doesn't have the provisions in stock form to control the IABs found in the B18C1's dual stage intake manifold. So if you go with the P61 and you still have the OEM B18c1 manifold on there, you'd probably wanna run with the IABs open (Just disconnect and cap off both ends of where the vacuum line was running from the manifold to the vacuum diaphragm) Without tuning to compensate for them being open all the time you'll lose some low end, but your top end would suffer terribly if they were left shut.
TheCrimsonGhost666
Jun 6, 2010 08:42 AM
j-spec_cc2
May 13, 2006 08:54 AM
