HELP QUICK!! vtec p06 conversion.(rm11)
Old Aug 2, 2010 | 06:14 PM
machine4321's Avatar
Default HELP QUICK!! vtec p06 conversion.(rm11)
Hey , in the middle of a p06 conversion. the resistors never made the trip and i need this up and going by the morning. The resistors i need are for the rm11 area.
I have tested resistors i have kicking around. i have lots of 10k
i have a 47k This should be a 51k
and a 15k this should be a 12k
Do you guys think this will work. Thanks in advance for the help.
Old Aug 2, 2010 | 08:38 PM
Default Re: HELP QUICK!! vtec p06 conversion.(rm11)
never mind. the resistors were the right value, they read different in the board. still code 21 (works with other p28.) not sure what the problem is but i have removed the parts i neded to get my p28 working (q31 and iat code.)
Old Aug 2, 2010 | 11:31 PM
mouab18c1's Avatar
http://xenocron.com/install/
Old Aug 3, 2010 | 04:07 AM
Thanks, i did chek that out before. alll the parts were installed but the ecu hasnt been used in many years. the guy couldnt remeber if it worked for him or not. I resoldered every thing and still no go so i dont know hat is wrong with it. still has code 21
Old Aug 3, 2010 | 02:14 PM
mouab18c1's Avatar
Did you try it in another car?
Old Aug 3, 2010 | 02:50 PM
no but the vtec worked on my other p28
obuhmyuh
Feb 25, 2008 12:48 PM
teleto69
Aug 2, 2006 09:26 AM
95accordh22a
Apr 8, 2005 08:03 PM
jack25racing
Sep 11, 2002 08:16 AM
