Running extremely rich
Old May 31, 2010 | 10:57 AM
3rdman's Avatar
Default Running extremely rich
00 si chassis, 01 b18c N/A fully built
now at completely stock fuel system and 2nd set of injectors
after 30 seconds into a cold start aem wideband reads 10.0 and cat starts to glow.
prior to the 30 seconds into the start. it reads 14.6 14.8.
car will not idle on its own.
Both Stock ecu and obd1 chipped with basemap ecu does the same thing.
Pull the plugs and there black!
Black smoke when running as well.
Fuel press at prime is 40psi, then between 36-38 when running
Ive tried my AEM FPR also and still does the same thing.
Only thing not stock in the fuel system is a AEM rail everything else is stock
motor is 12.61:1 comp. stock bore fully built head no P&P
SK2 intake mani and TB, hondata intake mani gasket
stock ignition
I have searched and havent found anything similar to my problem.
Old May 31, 2010 | 02:32 PM
mouab18c1's Avatar
Default Re: Running extremely rich
You need a tune. You also need a basemap made for your setup.
Old May 31, 2010 | 04:57 PM
3rdman's Avatar
I have a basemap already, it does the same thing with my stock EM1 ecu and my basemap obd1 p28.
Motor should not be rich to wear it will not run at all with a stock fuel setup on a high compression built motor right?
Old May 31, 2010 | 09:36 PM
mouab18c1's Avatar
It would actually make it lean if it's not feeding enough fuel. What size injectors do you have?
Old Jun 1, 2010 | 05:38 AM
3rdman's Avatar
Stock fuel setup currently
Old Jun 1, 2010 | 08:50 AM
mouab18c1's Avatar
You need a tune, and when you say fully built then it definately needs a tune.
Old Jun 1, 2010 | 09:50 AM
3rdman's Avatar
should not be rich on stock ecu with stock injectors not 10.0 or below AFR thats nuts
Old Jun 1, 2010 | 11:05 AM
mouab18c1's Avatar
Then either your afr gauge is off or your ecu is messed up. The ecu is what indicates how much fuel is being fed to the motor so I dont know. With that high of compression a tune wouldnt hurt. Either tune it and save the motor or leave it as is and blow the thing up.
1baddcivicsi
Oct 29, 2006 08:26 AM
redlseg
12
Aug 12, 2005 04:44 AM
stealthhatch
Feb 9, 2005 09:24 PM
