b20 afr in the 9's need help
Old May 18, 2010 | 07:57 PM
si90rex's Avatar
Default b20 afr in the 9's need help
im sure the afr guauge is right becuz crusing speeds are between 12's-13's but idle is 9's-10's. it starts fine, runs fine and doesn't smell rich. the basemap i have attached is a stock b20 or so i was told can someone help.
Old May 18, 2010 | 08:00 PM
si90rex's Avatar
Default Re: b20 afr in the 9's need help
attached
File Type: zip
Old May 18, 2010 | 08:13 PM
mtber's Avatar
Check your intake air temperature sensor to make sure it is within spec.
I have seen cars have a burnt sensor & not throw a code...
The basemap you posted looks a little weird but not enough to cause the car to run that rich.
Old May 21, 2010 | 08:54 PM
si90rex's Avatar
replaced today no change
Old May 21, 2010 | 08:58 PM
mtber's Avatar
Didn't tell you to change it. Told you to check it :-)
You could have ohmed it out and saved your self $.
Make sure your cam timing is spot on. TDC
How much vacuum is the car pulling at an idle?
Have you tried leaning the fuel map out?
You may want to post your complete setup specs on here to get more assistance.
Ultimately you may have to take the car to a tuner in person to have it tuned.
Old May 22, 2010 | 10:35 AM
si90rex's Avatar
stock b20 tri-y header and short ram intake. I been trying to lean out the car but my laptop needs a new battery it lasts about 20mins and its dead. cant get much done by the time it dies. timing dead on. i have had a spare intake temps senor.
Bobby Montalvo
Engine Management and Tuning
Sep 22, 2015 09:49 PM
D.a.z
May 12, 2014 08:06 AM
johnnypants
Aug 10, 2011 09:34 PM
egcrew02
Jan 16, 2009 07:23 AM
WhiteEkCivic
Oct 24, 2007 02:17 PM
