OBD0 to obd1 problems with check engine light.
Old Jun 18, 2010 | 03:05 PM
akurtzer57's Avatar
Default OBD0 to obd1 problems with check engine light.
I have a 1990 with b20z. I did a obd1 conversion. I checked my wiring on my dizzy it is good. Using a ecu jumper harness. Car starts right up and runs great for a second or to. Kind of misfires then runs like crap and is real sluggish trying to rev. I have obd1 chipped pr4. The check engine light comes on but I can't find out how to ground the scs wire to check for codes. I found the green with orange stripe on the obd0 harness I tried grounding and nothing. I need to figure this out asap. I am carless because of can't even drive the car like this.
Old Jun 18, 2010 | 03:09 PM
mtber's Avatar
Default Re: OBD0 to obd1 problems with check engine light.
Find the pin for the service connector & ground it.
Check http://www.phearable.net/tech for an obd1 wiring diagram.
Check the codes & resolve them
Old Jun 18, 2010 | 03:57 PM
akurtzer57's Avatar
I know its b6. I tried grounding it and nothing. I tried splicing into that wire on the obd0 harness. Then tried to hook a jumper into 2 plug under dash and nothing. I also cut the wire and tried doing it ecu side and harness side. What am I doing wrong here. I know ill feel like an idiot when get it right.
Old Jun 19, 2010 | 06:10 AM
mtber's Avatar
1. Wait for the check engine light to turn on with the car running.
2. Ground the service connector pin to a common ground in the vehicle.
3. Wait for the MIL to blink the codes.
Old Jun 19, 2010 | 09:57 AM
akurtzer57's Avatar
just tried that. Also tried to drive it. If I rev to 3000-3200ish it cuts out and won't go past.
Old Jun 19, 2010 | 10:58 AM
akurtzer57's Avatar
Tried my ecu in a buddys car. It worked fine. Going to check out tps later.
Old Jun 19, 2010 | 09:37 PM
mtber's Avatar
The purpose of the steps provided above was to get the MIL to flash what ever codes are being thrown. Something is obviously wrong with your wiring/vehicle.
Old Jun 21, 2010 | 11:53 AM
ej1project's Avatar
well if its a 90 then its not supposed to flash on the dash i thought it was supposed to blink on the ecu its self and since you have an obd1 ecu it doesnt have that light
Old Jun 21, 2010 | 02:55 PM
akurtzer57's Avatar
Yes I know that. Thats why suppose to ground the scs and it will blink.
Old Aug 2, 2010 | 01:20 PM
JDMmadness's Avatar
i have same exact problem, the obd0 to obd1 harness i got from zerg is ****, male pins on the harness are to small and doesnt give strong connection,
suburban_ninja
Oct 31, 2013 11:21 AM
Jdmefsir12
Jul 1, 2012 08:13 PM
craig88crx
Engine Management and Tuning
May 30, 2010 08:17 AM
91highryda
Oct 6, 2007 08:24 AM
turborex2
Jul 22, 2005 07:13 AM
