TPS voltage issue on Neptune
Old May 31, 2010 | 02:25 PM
mouab18c1's Avatar
Icon2 TPS voltage issue on Neptune
Why does my Voltage for my tps read 4.33 volts at WOT with the car off and only 3.4volts when actually flooring my car? I did two datalogs and still same results. Where could my problem be?
Old May 31, 2010 | 04:07 PM
93turbo16's Avatar
Default Re: TPS voltage issue on Neptune
Verify that your TPS is installed properly in the slots of the throttle body.
Also make sure all your grounds, etc are secure.
Old May 31, 2010 | 09:34 PM
mouab18c1's Avatar
Its on pretty tight and calibrated correctly. My grounds seem to be fine but you never know.
Old Jun 1, 2010 | 04:09 AM
GhostAccord's Avatar
Try doing the TPS voltage test, with the car not running, and have someone push your accelerator pedal to the floor. It maybe your throttle cable or pedal that is the problem????
I don't see anywhere in Neptune that you can do a TPS calibration so I guess that is out of the question.
Old Jun 1, 2010 | 07:04 AM
HRTuning's Avatar
TPS Calibration is there as soon as you open preferences. That's the problem, he calibrated it with the car off and it's not running the same voltages with the car on.
Old Jun 1, 2010 | 08:06 AM
Got it!
I'm so used to finding TPS calibrations in the start-up or in with the other sensor parameters.
Old Jun 1, 2010 | 08:27 AM
HRTuning's Avatar
Thinking about moving it.
Old Jun 1, 2010 | 08:40 AM
mouab18c1's Avatar
So am I suppose to calibrate it with the car on or off?
Old Jun 1, 2010 | 08:49 AM
HRTuning's Avatar
It shouldn't be different.
Old Jun 1, 2010 | 08:51 AM
mouab18c1's Avatar
Thats what I'm thinking, which leaves me at nothing then either buying a new tps and trying it out or something.
Old Jun 1, 2010 | 10:08 AM
Relic1's Avatar
since the TPS is a simple potentiometer, if the WOT voltage changes from Koff to Kon it has to be one of a two things.... the 5V reference voltage lowers or the pot itself is bad.
(thought of ground offset but that would still result in the same voltage to the ECU)
Both are easy to check with a volt meter and a little wire.
Old Jun 1, 2010 | 11:00 AM
mouab18c1's Avatar
You mean the tps is bad when you say Pot?
Old Jun 1, 2010 | 11:35 AM
Does your datalog show that you are @ 100% throttle @ 3.4v?
Old Jun 1, 2010 | 12:32 PM
Relic1's Avatar
"since the TPS is a simple potentiometer"
yep.
but if it's bad you should be able to watch the value with Koff and push in on the accel pedal slowly... the voltage will jump around and not be smoothly increasing.
Old Jun 1, 2010 | 01:48 PM
mouab18c1's Avatar
yep.
I'll give it a whirl. Thanks
Old Jun 2, 2010 | 06:27 PM
mouab18c1's Avatar
Tried it out the Voltage was smooth all the way through to WOT. So what can it be wiring?
Old Jun 2, 2010 | 07:53 PM
Relic1's Avatar
looks like the pot seems ok... what about the 5V reference?
Old Jun 3, 2010 | 10:28 AM
mouab18c1's Avatar
Havent looked at the 5V reference yet.
Old Jun 3, 2010 | 10:57 AM
HRTuning's Avatar
You'll want to test the reference with the car off and then on.
NEEDBOUTTREE5O
Feb 10, 2012 02:42 PM
UKintegra
Jun 8, 2011 12:32 PM
skuded
Engine Management and Tuning
11
Dec 15, 2010 02:07 PM
h2bv8killa
Aug 16, 2007 02:14 AM
guywitaDA
Dec 29, 2005 10:24 PM
