My AC is not cold enough.
Old Jul 9, 2010 | 01:58 PM
///EJ6POWER's Avatar
Icon6 My AC is not cold enough.
Ok well i bought two cans of AC Recharger 134a from walmart. i put 20oz. of it on my car and the max is 22oz. how can i make it colder! the AC is not super cold like other cars>?
Old Jul 14, 2010 | 01:50 PM
psv4878's Avatar
Default Re: My AC is not cold enough.
maybe your expansion valve is bad. or your compressor
Old Jul 17, 2010 | 09:10 PM
OMGRHD's Avatar
If you add too much refridgerant it will not work properly either. The only proper way to fix it is to recover the refridgerant from the system. Then pull the system into a strong vacuum. Then you can add your proper amount of refridgerant. Your best bet will probably be to go to a mechanics shop. The shop I work at charges about $100 to recharge your ac. If you add refridgerant to a completely empty system you will have air in it. This reduces the performance of your ac. I hope this helps.
Kyle
Old Jul 19, 2010 | 10:09 PM
hey i noticed there is a chemical, i think its water coming out of the ac pipe line. would that be considered a leak? is that why it might be affecting the ac system?
Old Jul 20, 2010 | 06:59 AM
MrDomino's Avatar
How the hell does this belong in the engine management and tuning section? Learn to read.
MyWhiteEJ6
Aug 16, 2013 10:34 AM
CivicSD
Aug 20, 2007 08:40 AM
vietnogi
May 24, 2005 08:01 AM
