chiped ECU o2 sensor?
Old Jul 29, 2010 | 10:25 AM
2kdrift's Avatar
Default chiped ECU o2 sensor?
just got my chiped p28 spec ecu from phearable .net
its not giving cel for 02 which it should as i have no o2 hooked up. do chipped ecu's generaly use o2's?
*its possible it still uses it but just dosent throw a cel
BTW phearable.net great product the basemap they gave me works well on my boosted setup
Old Jul 29, 2010 | 11:27 AM
mouab18c1's Avatar
Default Re: chiped ECU o2 sensor?
Im sure they probably crossed it off. Also depending on which obd you're running. If its an obd2 then the an obd1 ecu will not support some of the sensors that the obd2 motor uses.
Old Jul 29, 2010 | 11:56 AM
2kdrift's Avatar
ok thanks bro. im obd 1 ofc
Old Jul 29, 2010 | 12:01 PM
egsleepercivic's Avatar
phearable disables 02 sensor with their maps
Old Jul 31, 2010 | 05:14 PM
2kdrift's Avatar
yup they do for sure thanks peeps
Old Aug 1, 2010 | 01:55 PM
Chris@TDC's Avatar
Beware of using a basemap for driving around. Your basemap should only be used for checking for leaks, etc. and driving to the dyno to get a real tune.
Good luck with your setup!
duf2570
Apr 23, 2014 08:20 AM
Sagara09
Mar 14, 2012 06:47 PM
Slammed_am
Jan 9, 2007 09:17 AM
ph0shizzle
Aug 26, 2006 02:49 PM
mugenhatchie
Apr 6, 2005 09:35 PM
