Hondata S300 USB issues
Old Aug 8, 2010 | 07:50 AM
highboostcivic's Avatar
Default Hondata S300 USB issues
I am having issues with uploading the map to the ecu. The car has been down for about two months while I gathered the parts and now that I try to upload the map, the computer is not seeing the Hondata. I tried two different USB's and the options are still blank while the ignition is on. Even if I unplug it and replug it, there is no message tthat usually says a new device is connected or the sound that one makes when connected. I tried updating it in hondata but that doesn't work either. I even went into device manage and it is no there in the USD controller listing. What should I do, as this was working perfectly before I tore the engine down two months ago. Thanks.
Old Aug 9, 2010 | 10:29 AM
Spunkster's Avatar
Default Re: Hondata S300 USB issues
Check your wiring in the engine bay...especially grounds. It sounds like the ECU may not be powering up.
crxb16a90
Engine Management and Tuning
Aug 10, 2009 08:13 AM
mtber
Jul 31, 2007 01:38 PM
jdm ek9 101
Jun 27, 2006 12:40 PM
philo
Mar 17, 2003 09:11 AM
