can you please help me?
Old Jul 13, 2010 | 08:42 PM
mscp0012's Avatar
Icon6 can you please help me?
Here we go:
My car was fine. I brought it to my mechanic to get the timing belt changed.
My mechanic is my brother. So i watched the whole thing. He finally got everything back toghether after changing the belt. He started the car and it sounded.... messed up. Kind of like it was struggling to keep going. He looked around and realized that he forgot to tighten a bolt. (I AM NOT A MECHANIC) He tightened it and restarted the car. This is where this list of problems started.
It was still struggling to keep on. Kind of like it was running out of gas or something. The green key light lit up and has not gone away ever since.
We tried to attach a OBDII to erase the error message from the ECU but the OBDII gives a message saying "can not connect".
Now every time i start the engin after sitting, the first time usually kills the engine. Then i start it again and it runs fine. Yet the green key light still blinks.
Yes i am using my real key and not a copy, i have a copy and tried it too it did start but didnt get rid of the green light.
Also when i drive, the temperature guage doesnt work, the rpms doesnt work, and the engine light is on and the green key light is blinking.
On top of this, my car being standered, i start in first gear and can not accellerate past 20km, then second cant go faster then 40km, then third cant pass 60km, then fourth cant pass 70km and fifth cant pass 110km.
I have checked to find any wires that havent been placed back. I have used 4 OBDII units and they all cant connect, i have checked all fuses in the car and under the hood. i have also left the battery off for an hour which reset everything but the error.
My brother said to go to honda and get the key re-registered or something and then i would be able to get rid of the green light and then erase the error in the ecu.
is this correct? is there anything I can do without going to honda and not drive a .. messed up car.
Old Jul 13, 2010 | 09:04 PM
mscp0012's Avatar
Default Re: can you please help me?
Also I am not sure if this relates to this problem but I had trouble with my passenger door look when I pressed the lock button on the key chain. It would not lock, so we ordered a part for the doors and changed those but both doors locks and windows work fine.
Old Jul 14, 2010 | 08:12 AM
mouab18c1's Avatar
Check all ground wires. Recheck your timing belt to make sure its at TDC. What year and model is this car your talking about? Plus you posted in the wrong forum.
Old Jul 14, 2010 | 09:03 AM
mscp0012's Avatar
2001 honda covic 2 door sport(i think its sport ... or coupe? )
mscp0012
Honda Civic (2001 - 2005)
37
Mar 19, 2024 07:27 AM
sleepyitr
May 1, 2008 04:22 PM
cliff666
Jun 4, 2005 04:55 PM
94_CRVtec
Apr 23, 2005 10:26 AM
kicker1_solo
Apr 18, 2004 03:28 PM
