s300 tuning questions
Old Jul 6, 2010 | 05:19 PM
eg6madness's Avatar
Default s300 tuning questions
while tuning my injector (ms) turned red around 5000 rpm, however the duty cycle is around 70 %. what exactly do these mean?
also my MAP reads 0.0 to -0.7 at some areas and also turns red. is this an issue?
Old Jul 6, 2010 | 05:56 PM
mtber's Avatar
Default Re: s300 tuning questions
You can adjust the points at which the color will change on the "display" you are referring to.
Right click & click properties on which ever you would like to adjust...
Old Jul 7, 2010 | 05:51 AM
eg6madness's Avatar
i know i can ,
What i am asking is if using the factory defaults, does that mean that my injectors are maxing out ?
cant what does the reading od the MAP mean?
Old Jul 7, 2010 | 12:28 PM
mtber's Avatar
Originally Posted by eg6madness
i know i can ,
Ignore it, adjust the max & min values for the warning colors.
Old Jul 7, 2010 | 12:49 PM
eg6madness's Avatar
ok cool, so the only injector reading i should really be concerned with is the duty cycle?
and yeh my max value was 10, so when it got over that then it went red, my max injector (ms) value is 15.07
SuperSlowEF8
12
Jun 27, 2011 03:06 PM
85mmek9
Paint and Body
Jul 27, 2010 12:41 PM
MugenHonda
Jul 3, 2005 07:21 PM
xstalkrx
45
May 13, 2005 05:50 AM
