wiring up launch control
Old Jul 1, 2010 | 09:38 AM
that-guy's Avatar
Default wiring up launch control
so i wired up most everything from my SEM, and now there are two wires for launch control, one is for launch ground, and the other is input, where does the computer get the signal from for launch control?
Old Jul 1, 2010 | 08:16 PM
that-guy's Avatar
Default Re: wiring up launch control
44 views and still no answer...........
Old Jul 1, 2010 | 08:32 PM
SL0WEGG's Avatar
signal to activate launch control?
Old Jul 2, 2010 | 09:51 AM
THC07's Avatar
yea! what?
this a fuel cut or ign cut that you're setting up?
Old Jul 2, 2010 | 05:51 PM
likwidchz's Avatar
wow.. come on people..
Generally features like this get the input from an unused pin on an ecu.
which pin you can use
Obd1 pins you can generally use... if i miss one feel free to comment in the correct
ok for instance in neptune RTP
You have to look in your manual to see how to activate the inputs/outputs
--Aaron
Attached is a photo for pin examples
Rydo
Honda Civic (2001 - 2005)
30
Aug 17, 2011 03:24 PM
noble4ws
Aug 23, 2004 12:21 PM
Problemo
Jun 19, 2004 08:57 AM
