Chipped p06 ECU quit working?
Old Jul 18, 2010 | 08:32 PM
mouab18c1's Avatar
Icon2 Chipped p06 ECU quit working?
Im wondering why my chipped ecu quit working? I opened it up to see if there was any burnt spot but it looks fine to me. It quit working after a 10 minute drive back home from work. Only reason I could think of was that there was a stupid wire sticking out from a wire connector by the ecu that I connected the night before. It must of caught something and stuck back out but the wire was ticking as I was driving. FYI CEL 4 popped up as well but after trying to start it after an hour it just wont start anymore. ANy idea?
Old Jul 18, 2010 | 08:42 PM
mouab18c1's Avatar
Default Re: Chipped p06 ECU quit working?
Shitty picture but I mean if it was burnt wouldnt it be visible? j12 is the only thing missing.
Old Jul 18, 2010 | 09:19 PM
HRTuning's Avatar
Could be quite a few things, actually. Is the fuel pump priming? Does the CEL come on immediately and just stay on?
Old Jul 18, 2010 | 09:25 PM
mouab18c1's Avatar
With the key to the On position no Cel on at all. I swear I hear it prime but my freaken spark plugs look dry as heck after cranking it for awhile.
But another question my brothers chipped p28 ecu that he just baught has a CEL on at all times. Cant even jump that fckuer. Whats wrong with his?
Old Jul 18, 2010 | 10:12 PM
HRTuning's Avatar
Sounds like he's in limp mode. Sounds like yours has a power management problem. Could be the voltage regulator, cap, or a long series of other things!
Old Jul 19, 2010 | 06:53 AM
mouab18c1's Avatar
So there is really no way to figure out what part of the ecu is messed up?
Old Jul 19, 2010 | 07:46 AM
HRTuning's Avatar
Of course there is. Tracing over every component in order until you find the culprit.
Old Jul 19, 2010 | 07:50 AM
mouab18c1's Avatar
Do you know if j12 is supposed to be cut? Thats the only thing i see missing and according to xenocrons website it doesnt state anything about cutting j12
Old Jul 19, 2010 | 08:15 AM
mouab18c1's Avatar
NVM found my answer for j12
Old Jul 19, 2010 | 08:50 AM
mouab18c1's Avatar
Alright update. So I got sick of it and threw in my old Crome chip back in it to see if it would start my brothers car. Boom it starts up and idles like ****. Jumped the ecu and it had CEL 4 like it did in my car before it wouldnt start anymore. So now the question is which part of the ecu controls CEL 4?
Old Jul 19, 2010 | 08:59 AM
mouab18c1's Avatar
It says that b13 and b14 control the TDC sensor according to this website
http://www.jspecauto.com/files/jspec...chcenter1g.htm
Old Jul 19, 2010 | 09:21 AM
HRTuning's Avatar
If the ECU still runs look into your wiring first, or possibly your distributor.
Old Jul 19, 2010 | 11:54 AM
mouab18c1's Avatar
It only runs on Crome. Not on Neptune. I tried it in two different cars. Idles like crap and it throws CEL 4 in both vehicles.
Old Jul 19, 2010 | 12:18 PM
HRTuning's Avatar
Right, it runs, that was my point. Fix the problem and viola.
Old Jul 19, 2010 | 12:50 PM
mouab18c1's Avatar
Well thats the thing how do I fix b13 and b14? Which part of the ecu works with the TDC? You make it sound so easy hahaha
Old Jul 19, 2010 | 01:10 PM
HRTuning's Avatar
Old Jul 19, 2010 | 01:19 PM
mouab18c1's Avatar
hows that possible with 3 cars?
Old Jul 19, 2010 | 01:28 PM
Turbogixxer's Avatar
you may want to take the ECU to some one that can check it.
Old Jul 19, 2010 | 01:30 PM
mouab18c1's Avatar
I was thinking about sending it to Xenocron.
Old Jul 19, 2010 | 01:33 PM
Chris is good!
JR may help you with it too (HRtuning). He can test it, but you would have to ask him.
Old Jul 19, 2010 | 01:38 PM
HRTuning's Avatar
No conversion harness? I won't be able to help out, unfortunately.
Old Jul 19, 2010 | 01:50 PM
mouab18c1's Avatar
My Gsr has an obd2a-obd1 jumper harness for the p06. My brothers car was wired for obd1 so no jumper harness needed and i also plugged it into my buddys eg. All with the same results. Shitty *** idle and Cel 4.
Old Jul 19, 2010 | 02:13 PM
HRTuning's Avatar
Gotcha.
Old Jul 21, 2010 | 11:45 PM
nge's Avatar
nge
if you connected vtec solenoid and pressure switch. it maybe a blown capacitor
Old Jul 22, 2010 | 08:01 AM
93turbo16's Avatar
Another thing to look at would be the main cap at C14. They fail a lot, I always replace it when chipping an ecu.
