to tune or not?
Old Jun 30, 2010 | 06:23 PM
civicsirebuild's Avatar
Default to tune or not?
hey guys, i need some help here. ive got a 2000 civic si, b16a2, with sri, no cat con, and exhaust. i recently rebuilt the motor due to burned valves, one of which had a hole in it you could put your pinky thru. with only 140k mi, im assuming its running lean to have done this. i also had a pnp done while it was out. now, question is does it need to be tuned to get the right a/f ratio? if so what do i need/where do i go? are there any tuners near west ky? thx
Old Jul 1, 2010 | 07:19 AM
THC07's Avatar
Default Re: to tune or not?
Of course it need to be tuned.
Reason nobody is replying is probably because they feel you didnt make an effort to search.
there is a list of tuners here on HT. "if so what do i need/where do i go?" ugh! you need a tune, and you need to go to a tuner to get one. right?
poke around with the search button, it works well/
