p28 chipped and tuned ECU problems
Old Mar 27, 2017 | 05:38 AM
danielb2098's Avatar
Default p28 chipped and tuned ECU problems
hello guys about 2 years ago i posted starting problems with my b20b swap. the car was not starting or it would shut off while i was driving. when the car would shut off it would kick on the check engine light. it would not start untill the fuel relay would click over then the check engine light would turn off so at first i thught it was the relay switch but then a buddy of mine brought over a stock ecu for the car and since then it has has no issues except my car does not run like it did witht the mapped and tuned ECU. any suggestions on what could be wrong with my tuned ecu i am not to sure at all when it comes to ecu's anything will help thanks guys. also i did change out the relay twice both fuction properly.
Old Apr 1, 2017 | 05:18 PM
motoxxxman's Avatar
Default Re: p28 chipped and tuned ECU problems
infinite possibilities. best bet to start is take very close up detailed pics of both sides of the ecu board so we can try and spot anything wrong. next step would be to send it to someone for testing and repair.
I can do this, or any of the known honda ecu guys can as well like xenocron and phearable.
Old Apr 4, 2017 | 04:52 PM
Txdragon's Avatar
Check and double check (CLOSELY) your 28 pin solder points and J1 jumper.
Old Apr 5, 2017 | 12:35 AM
bulito's Avatar
also check IC17
allums34
Feb 20, 2011 09:10 AM
I CRX I
Engine Management and Tuning
Jul 30, 2010 09:15 PM
trunkluv
17
May 30, 2010 08:02 AM
Red_Si
Apr 29, 2003 10:27 AM
