cant get freelog to work
Old Aug 28, 2016 | 05:40 PM
cityofcaterpillars's Avatar
Default cant get freelog to work
I set up my Ostrich and Hulog yesterday. I'm using Crome Free and Freelog on a P28 ECU. J12 is cut. I don't have a wideband yet so Im not making any changes to the basemap just looking around the programs.
When I run Freelog it just gives random numbers for everything and I have no idea what to do with it
Any help>?
Old Aug 29, 2016 | 09:01 AM
7rrivera7's Avatar
Default Re: cant get freelog to work
Sounds like incompatilbel comm port settings - Baud rate, stop bits, etc...
Old Aug 29, 2016 | 11:29 AM
How would I fix that
Old Aug 30, 2016 | 12:36 AM
forbiddenera's Avatar
Is your ECU modded for full duplex communication? Pretty sure you'll need to do this for it to work proper if you haven't.
Old Aug 30, 2016 | 04:56 AM
this is the kit I used to chip it.
ECU Chipping Kit - Phearable.net
I did cut J12 which should have made it full duplex.
Maybe I have the data logging header in backwards?
Old Aug 30, 2016 | 06:19 AM
It's possible, the headers orientation itself shouldn't matter, what matters is that whatevers plugged into it (hulog?) Is connected properly. I've never used a hulog, just a datalogging cable I made myself with an ftdI chip and stuff..
Have you tried connecting with crome? I haven't used crome in a while but the free version should have logging too? It was crome qd2 for free and qd3 for pro I believe, protocol-wise.
You should consider eCtune, pm me if you want to.
Old Aug 30, 2016 | 07:52 AM
The Hulog seems to connect fine to the pc. Crome free doesn't have data logging. I tried downloading eCtune but every time I try to run it it says unable to find native library
Old Aug 30, 2016 | 07:54 AM
sent PM
Jnantz00
Engine Management and Tuning
14
Jan 24, 2016 09:59 AM
Veggie Man
11
Jun 14, 2015 04:20 PM
x_doug-x
Jan 5, 2012 08:21 PM
Buitrex
Feb 24, 2010 12:11 PM
snowblind7x
Nov 3, 2005 05:25 PM
