Idle problem only when I give it gas
Old Jul 9, 2016 | 05:38 PM
Jeanp123's Avatar
Default Idle problem only when I give it gas
I swapped out my auto d16y7 with a manual d16y8 with Ecu and intake manifold and has no idle problems. But when I give it light gas to take off, it idles quick up and down causing my car to jerk a lot when taking off. Here's a link to the video I uploaded https://www.youtube.com/watch?v=yO-urbfTXjk&feature=share please help all ideas welcome just trying to figure it out thanks
Old Jul 10, 2016 | 01:30 PM
v4lu3s's Avatar
RTFM
Default Re: Idle problem only when I give it gas
have you set idle per the factory service manual?
Old Jul 10, 2016 | 06:31 PM
Jeanp123's Avatar
How would I do that?? Please explain
Old Jul 11, 2016 | 07:10 AM
seelback's Avatar
is the wiring harness a manual dy16y8 harness? From what i know, all d16y7 and auto d16y8 use 3 wire iac valves and manual d16y8 use 2 wire iac valves. There's write ups on how to fix the wiring problem you may be having. Just do a google search. Hondata has in there s300 help files for a procedure on setting idle.
djandy
14
Aug 28, 2014 10:10 AM
Apple395
Aug 7, 2013 12:38 PM
ITLNstallion818
Aug 11, 2007 08:35 PM
JunY
15
Jun 30, 2005 08:55 PM
dubniK
Jun 12, 2004 08:49 PM
