d16z6/y8 ignition base map
Old Aug 3, 2016 | 12:58 PM
cityofcaterpillars's Avatar
Default d16z6/y8 ignition base map
Here's what I have
D16Z6 block
Y8 head
B7 dizzy
Z6 crank pulley
I am trying to set the ignition timing and my marks are not even close on the crank pulley. I was thinking it was maybe because the timing on the P28 ecu is 16 degree and the timing on a P2P ecu is 12 degree.
If this is the case could I fix this with a chip from phearable? And if so what would I need to tell them.
Thanks in advance
Old Aug 4, 2016 | 04:52 AM
Turbokraft's Avatar
Default Re: d16z6/y8 ignition base map
What cam and cam gear are you using? A z6 setup will probably resolve your problem, alternatively you could enlarge your distributor slots.
Old Aug 4, 2016 | 06:18 AM
I had a y8 cam gear on it. Some one suggested using a Z6 cam gear. Which I have an adjustable one. I'm not sure how to adjust the Z6 cam gear for this setup though.
I didn't think about the timing marks being different on the Z6 crank pulley versus the Y8 one.
I'm going to try switching to the y8 pulley.
Old Aug 5, 2016 | 04:37 AM
Turbokraft's Avatar
Remove your adj. and overlay it w/Z6 sync them for a baseline.
Old Aug 5, 2016 | 05:36 AM
So basically use a stock Z6 cam gear? Won't that then throw off my mechanical timing?
Old Aug 7, 2016 | 10:44 PM
VegasInvasion's Avatar
I'm Huge In Japan
you need an adjustable cam gear, it's 4.5* off from the Z6 block.
set your crank to TDC
align the cam to TDC
lock your base timing to 12*
adjust dizzy timing.
If it's more than 10* out, your cam is off a tooth.
I have the same setup.
Make sure to adjust valve lash after you're done
cityofcaterpillars
39
Aug 15, 2016 09:25 PM
powrachute
Dec 15, 2009 09:57 AM
91integraLSVTEC
Mar 28, 2008 05:52 PM
Forty04
Apr 24, 2007 06:48 AM
eg4door
23
Jun 20, 2005 04:10 PM
