Help check engine light blinks
Old Nov 19, 2016 | 01:27 PM
hondaracing420's Avatar
Default Help check engine light blinks
I have a 98 civic ex d16y8 changed dizzy new plugs new wires . Now it starts up and idles fine . It's when u drive it when u start in first gear it shakes and on take off if I put the pedal down it boggles then clears out then same thing with other gears . Check engine light blinks ?? Is it fuel injectors?
Old Nov 22, 2016 | 06:10 AM
Mihopopvtec's Avatar
Default Re: Help check engine light blinks
Could you take a picture of the symbol that blinks?
Old Nov 22, 2016 | 06:22 AM
If it's automatic check your front transmission solenoid which is a tcu (transmission control unit. It's a silver or copper colored box under your passenger dash. That usually means your transmission is going into limp mode. It could also be that your car is in sport mode which u can turn on and off by the shifter.
Old Nov 22, 2016 | 08:19 AM
spAdam's Avatar
Loved
Community Favorite
There's no sport mode one a 98.
A flashing check engine light is typically an indicator for heavy misfire. It will flash during the events. Did it start this after you performed your tune-up?
alfiler
Feb 16, 2009 11:55 PM
91b16acrx
Apr 20, 2008 09:20 AM
civicgeek133
Apr 11, 2006 06:34 PM
OneOver
Oct 29, 2004 11:15 AM
CereaLand
Feb 7, 2003 12:55 PM
