ostrich windows error
Old Aug 19, 2016 | 01:13 PM
cityofcaterpillars's Avatar
Default ostrich windows error
Im trying to install Ostrich 1.0 on a windows 10 laptop and I keep getting the error
Windows has stopped this device because it has reported problems. (Code 43)
A request for the USB device descriptor failed.
How can I fix this?
Old Aug 19, 2016 | 03:38 PM
rhd91integra's Avatar
Default Re: ostrich windows error
try updating the firmware... ****.. windows 10.. HMM im on windows 7.. try going into Properities.. and make it run in windpws XP mode.. and always start in Admin Mode..
Old Aug 19, 2016 | 07:24 PM
I emailed moates and they told me that they didn't have a firmware update.
Old Aug 19, 2016 | 11:36 PM
It wont let me update the firmware because it can't detect the device. I even replaced the 3 AAA bateries and nothing looks burned on the board. I really hope I didn't get ripped off. Here are some screen shots.
Old Aug 20, 2016 | 06:35 AM
forbiddenera's Avatar
Check your USB cable. Otherwise, the board may have a bad usb chip.
Old Aug 20, 2016 | 06:42 AM
I tried a different cable and nothing. The data logger installs just fine using both of those cables so it's not that. Can the USB chip be replaced?
Old Aug 20, 2016 | 07:58 PM
Theoretically, I haven't personally used one, does the datalogger/emulator appear as two different USB devices or something?
Because if not and it's loading the driver, it's at least detecting the device IDs etc.. You need to be able to log the USB stuff somehow. Linux would be a good tool but there's no linux drivers probably but you could still find out if its connecting at all / what point in the connection it dies
Old Aug 20, 2016 | 07:59 PM
Looking at your errors again, it is possible the FTDI chip is having an issue, it would be replaceable though, yes. I bet Moates would help you fix it?
Old Aug 21, 2016 | 06:24 AM
The emulator and data logger are two separate units. FTDI does sell a replacement chip but it's tiny and I'm not sure how I would solder it being that it's so small
Old Aug 21, 2016 | 12:10 PM
Moates.. guarenttees there Products.. U can talk to David and he should Fix or Replace that Ostrich and send u another..
Of course there is No FIRMWARE updates LOL.. like i said before.. He asked why i wanted it.. cuz i wanted to update my firmware.. I searched and found it myself..
u need 10.20 firmware update to basically run like a ostrich v2.. and u need the 10.20 to connect to ectune.. etc..
i have all the firmware updates.. LOL.. Lmk if i can Help..
go to the moates website.. there is a download that wipes clean the FTDI drivers.. and try to reinstall again..
if that doesnt work.. try a different cablle w the ostrich v1.. if that doesnt work.. Its the UNIT that is Bad.. Unless u got another laptop to try and connect to,.
Old Aug 21, 2016 | 12:38 PM
^ best answer, what I was gonna say. They should fix it for you.
Old Aug 21, 2016 | 06:05 PM
I've been talking to David for the past few days. He has been pretty awesome. He told me to send it to them and they would repair it. Which is awesome seeing as I didn't buy it from them. So hopefully in a few weeks I will be up and running.
BLKFLSH
Oct 10, 2012 03:09 AM
mindping
May 30, 2009 10:08 PM
kap_x
Dec 16, 2005 08:56 PM
