Assistance Needed: Experiencing trouble with PLX Wideband AFR in Hondata S300
hi, i have trouble with plx sm afr
when i add extra fuel, my gauge is showing LEAN
if i return fuel settings, gauge is showing actual AFR
if mixture ~10-11 afr, gauge is showing 1-2 sec actual afr and show LEAN.
re: Assistance Needed: Experiencing trouble with PLX Wideband AFR in Hondata S300
have you tried testing the sensor? theres some vids on youtube I beleive from AEM
basically you soak a rag in carb cleaner/ brake clean, wrap the rag around the sensor it should show full rich....remove the rag and it should go full lean give it a try to make sure the sensor still functions properly
thanks!
