lsv turbo basemap
Old Jun 25, 2016 | 07:35 AM
DerekHollister's Avatar
Default lsv turbo basemap
im trying to get a basemap for my setup. purpose it to be able to drive it make sure it runs correctly no leaks and be able to drive to a tuner. its a lsv b16 head gsr cams 9.8:1 81.5 bore stock map 900cc injectors gt35r 10 lbs spring 68mm throttle body pro intake. i have hondata s300v3 tried the preset basemaps with my map and injector dead times but no luck.
Old Jul 5, 2016 | 02:26 PM
B20VtecVillain's Avatar
Default Re: lsv turbo basemap
Send me a PM with your email and I'll send you a map file that will work.
Old Jul 5, 2016 | 02:33 PM
Well thank you. I ended up getting one to work a buddy messed with his idle for his itr basemap and it ended up idling my car so I added my injectors and boost tables. Test drove it it fuel cuts at 5k under full throttle. Not sure what's causing that.
Mjalaly
Engine Management and Tuning
Jul 7, 2015 09:25 AM
b20turbocivic
14
Dec 28, 2009 11:31 AM
Dakota
Feb 4, 2009 01:20 PM
ONEQWKSI
Oct 27, 2008 09:17 AM
irocdaparty85
Jul 25, 2005 09:23 AM
