Normal IAT
Old Jun 17, 2016 | 02:43 PM
b16a971's Avatar
Default Normal IAT
I have a stock b16a on a ek chassis getting ready for turbo but i want to make sure everything is ok before i put the turbo on
I get 130 to 160 iat reading on hondata on a 90f weather. Is this normal?
Old Jun 18, 2016 | 11:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Normal IAT
Is the IAT sensor mounted between the air filter and throttle body or is it located in the intake manifold ???
Old Jun 19, 2016 | 01:50 AM
b16a971's Avatar
Its in the manifold. Is the iat temp normal?
Old Jun 21, 2016 | 08:44 PM
PGHintegra's Avatar
Ive never owned an na honda before but i just put an iat sensor right before my throttle body 2 weeks ago to play with some things cooling my intake temps down and im getting 100-110*f right now and its been like 90 degrees everyday. Id be pretty okay with your numbers seeing as you have no intercooler and your manifolds probably heatsoaked under the hood
Old Jun 22, 2016 | 09:00 AM
SpeedRacerEX-R's Avatar
Um, every OBDI and newer honda come with factory IAT. As far as what the temp is supposed to be, obviously the colder the better.
Veggie Man
Jan 17, 2013 03:16 PM
sk8kingda3rd
Jun 28, 2011 07:41 PM
TurboEK9Coupe
Apr 3, 2008 01:03 PM
hondatweakn
Oct 7, 2004 08:09 AM
XShadow
Feb 29, 2004 10:26 AM
