wired problem running lean while fully warm
Old Aug 21, 2016 | 08:27 AM
civicb1812345's Avatar
Default wired problem running lean while fully warm
Ok so I have a 94 integra b18c1 boosted 750cc injectors walbro 450 on a ebay 57 trim tuned on chrome by p/o. When I cold start the car in the morning afrs are 14.7~15.0 cruising 11.5~12.0 wot in boost. But as soon as it warms to operating temp afrs cruising are anywhere from 15.0-18.5. Wot boost jumps to 12.5-13.5. Car does have a civic half rad with fresh coolant. Im stumped and have researched can't find a answer anywhere. Please help
Old Aug 21, 2016 | 08:28 AM
Default Re: wired problem running lean while fully warm
Forgot to mention I'm on e85 also
Old Aug 21, 2016 | 10:02 AM
testify's Avatar
On vacation
The cooling system has nothing to do with AFRs.
Sounds like you need to get the car tuned.
Old Aug 21, 2016 | 11:59 AM
car has been tuned, and this just recently started happening, i should say i swapped the turbo motor in from a coupe. and in it it never has this problem this bad. when i got it it would move around a bit but never go above 15.5 or so.
Old Aug 21, 2016 | 12:30 PM
testify's Avatar
On vacation
YOU NEED TO GET THE CAR TUNED!
Change the hardware, change the tune. You have zero clue what kind of tune is on there since it was done by the PO. You can't change the turbo and use the same map. It doesnt work like that.
Get the car tuned.
Old Aug 22, 2016 | 04:39 AM
I didn't swap turbos. Motor came out of a coupe just like it is and went into integra. Nothing changed at all
Old Aug 22, 2016 | 06:47 AM
testify's Avatar
On vacation
Okay, good luck with it.
Old Aug 22, 2016 | 08:22 AM
averyvm's Avatar
Make sure there are no exhaust leaks before the wideband sensor. It may be a false lean condition due to exhaust leak that shows itself after the engine warms up.
Old Aug 25, 2016 | 02:21 PM
forbiddenera's Avatar
Get it tuned.
Crome sux
Old Aug 25, 2016 | 04:06 PM
pogeeboy27's Avatar
What injectors are you running? I notice your are on E85. If you are running older injectors that are not E85 compatible, you could run into an issue where heat and E85 closes up the injectors causing a lean condition.
Old Aug 25, 2016 | 08:04 PM
Thassa smart one.
Old Aug 26, 2016 | 12:50 AM
pogeeboy27's Avatar
Originally Posted by forbiddenera
Thassa smart one.
See links below.
ATTENTION: FIC 1680 & ID 1600cc injector owners - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
https://honda-tech.com/forums/engine...ecall-3006186/
Problem with Id 1600 ! - Engine - GT-R Life
G-Auto*Hero
Sep 14, 2010 10:31 PM
jake 92eg d16z6
Aug 7, 2009 07:36 PM
FinallyBoosted
Jun 7, 2007 09:37 AM
DelSolMike
Apr 16, 2006 05:20 PM
redciviclx14
Aug 12, 2003 09:36 AM
