Crome pro and quad cell smart tracking
So I'm using crome and trying to get a basemap cleaned up and going.
However i seem to have a problem with the Smart Tracking feature.
According to the documentation I've found online there should be a drop down arrow and the ability to swap from "single Cell" to "quad Cell"
The problem is I don't seem to have the ability to turn this on. I'm using crome version 1.6.16.
In screenshot i took you can see i'm missing the dropdown arrow that allows you to change the smart tracing settings
I know the ECU is averaging a range of 4 cells together to get the running value.
But since I can only manipulate 1 cell at a time its leading to a really lumpy map...
Do I need to go back to a much older version of crome to make this work or is there some other place I can set that up?
