ignition break up under high boost only
Old Aug 10, 2016 | 06:57 AM
eksleeper97's Avatar
Default ignition break up under high boost only
im currently on the dyno with a built ls vtec engine. only symptom is under high boost, over 24psi, it break up bad at 7000 rpms only everytime. on low boost, it runs great no issues. running a t1 cam trigger setup with rsx coils and aem v2 ecu. spark plugs are gapped at .015. ive added a few more grounds thinking im lacking most of the factory grounds, doesnt change anything. My tuner is currently lost as well am i.any ideas would be helpful!
velisma
Apr 22, 2010 11:50 AM
89edcivic
Mar 27, 2010 07:16 PM
LST2
Jul 10, 2007 06:15 PM
DEMNTD1
Jul 20, 2005 08:25 AM
Snafu-Si
Jul 12, 2003 10:12 AM
