Does engine knock disable VTEC?
Old Sep 8, 2016 | 01:33 PM
Stevieh62000's Avatar
Default Does engine knock disable VTEC?
As the title says.. My vtec currently isnt engaging, ive noticed some pinking under 2000rpm and wondered if this was enough to cut vtec?
other info. my vtec was working but i was loosing oil fast from my sump gasket. Vtec stopped working after getting this fixed. Ive spoke to the garage and they said the only plug they removed was the lambda sensor as they had to remove the manifold to remove the sump. Ive checked that this has been reconnected and it has.
Also im not getting a CEL light..
please help
Old Sep 8, 2016 | 06:54 PM
thescr33nn4m3's Avatar
Default re: Does engine knock disable VTEC?
Personally, if my engine was knocking I wouldn't be beating on it enough to need to hit VTEC; however, that's just me. Have you checked that your engine has the correct amount of oil in it currently?
Old Sep 8, 2016 | 09:56 PM
motoxxxman's Avatar
what ^he^ said.
also, you do realize the sump is in the oil pan, and you don't have to remove the exhaust manifold to get to it, just the downpipe.
you also can't lose oil by having a leaky sump. you sure can destroy the engine though by having a leaky sump gasket, because it will suck air instead of oil, and you'll have near zero oil pressure at all times
Old Sep 8, 2016 | 10:30 PM
ok maybe my wording was incorrect. The oil pan gasket was leaking and I was loosing a considerable amount of oil.
My oil level is currently slightly over filled, about 6mm over max level.
Old Sep 9, 2016 | 06:09 AM
Muckman's Avatar
Moderator in Chief
Check your oil pressure. VTEC requires a minimum amount of oil pressure to engage.
Also check your VTEC filter screen behind the solenoid for debris that can block flow.
Old Sep 9, 2016 | 10:17 AM
tony_2018's Avatar
Fish Twig
Check oil pressure and check your solenoid.
Old Sep 9, 2016 | 10:35 AM
I've replaced the solenoid for one I know works and nothing.
All that's left that I haven't checked is voltage at the solenoid at 6000rpm and oil pressure.
Old Sep 13, 2016 | 09:15 AM
update: Problem solved. The garage I took my car to removed the oil pan gasket and put it back on with sealant, this put the oil pickup to close to the bottom and caused a restriction. They have put a oil pan gasket on now.
Old Sep 14, 2016 | 05:34 PM
spAdam's Avatar
Loved
Community Favorite
Wtf?? I hope you never go back to that shop again. That's just plain hack right there, it wouldn't have stayed sealed for long anyway. Hopefully they didn't ruin the pan flange and mating face of the block in either of your visits.
Old Sep 17, 2016 | 05:18 PM
Muckman's Avatar
Moderator in Chief
Default Re: Does engine knock disable VTEC?
The oil pick up is not that close to the bottom of the pan where the thickness of the gasket will cause interference. It was probably dented in. I would be worried about your engine bearings now. Get an oil pressure gauge!
Old Oct 7, 2016 | 05:19 PM
B and B's Avatar
Loved
Community Favorite
Why didn't the oil light come on at least?
xxbvanxx
Jun 19, 2010 05:08 PM
josheezy
Mar 24, 2008 04:05 PM
GiT LaO'd
Nov 22, 2004 04:24 AM
Jammersplace
Jun 4, 2004 06:41 PM
