LS basemap on chipped P28
Old Aug 25, 2016 | 11:58 AM
evosix's Avatar
Default LS basemap on chipped P28
Will a chipped P28 run a LS basemap properly? I know in crome you can disable VTEC, just want to make sure that it will work since P28 ecus have the hardware components for vtec.
Old Aug 25, 2016 | 01:57 PM
B20VtecVillain's Avatar
Default Re: LS basemap on chipped P28
Yes the ecu will effectively be whatever ecu the program on the chip is. As long as the map is a P75, for all intents and purposes the ecu is now a P75. Also, is your engine going to be stock or does it have bolt ons and such? If its modified even a little, i would run a modified tune. Stock P75 will likely be safe, but you will be leaving significant power on the table. Even a simple intake/header combo on a B18 can cause it to want a solid 10-15% more fuel across the board, and the stock timing maps can stand to be cleaned up a lot on anything with spirited driving or performance in mind. If I can get Crome to work with Windows 10 again I would be happy to send you a Few BINs for a good LS basemap. I assume your not running S300 lol
Old Aug 25, 2016 | 08:05 PM
forbiddenera's Avatar
Won't be a problem. PM me if you want a custom eCtune basemap.
Old Aug 26, 2016 | 04:37 AM
evosix's Avatar
Thanks you, that was very helpful! No S300, just a chipped p28 and crome on a laptop/moates burner.
HondaVTEC1993
Engine Management and Tuning
19
Apr 26, 2018 09:02 PM
Ls_Turboteg
Dec 10, 2008 07:10 PM
4cylinders-of-fury
Sep 14, 2007 07:43 AM
JDMstatus95
Mar 2, 2007 10:24 PM
