Jdm b18c idle problem help plz
Old Jun 17, 2016 | 10:34 PM
Maw76's Avatar
Default Jdm b18c idle problem help plz
I have Jdm b18c in my 98 Integra , and it idles at 1500 rpm all the time ,it doesn't go down after getting normal engine running temp.
Old Jun 18, 2016 | 08:56 AM
7rrivera7's Avatar
Default Re: Jdm b18c idle problem help plz
Is the check engine light on? You might possibly have codes for the water temp sensor (ECT code 6) or the Intake Air Control Valve (IACV code 14)
Old Jun 18, 2016 | 10:47 PM
Maw76's Avatar
Hi ,
Yes the engine light on . I did block a hole for Iacv in throttle body. And after blocking with finger the rpm becomes normal to 800 .as soon as I unblock the hole rpm goes back to 1500.
Old Jun 20, 2016 | 05:46 PM
spAdam's Avatar
Loved
Community Favorite
You have a vacuum leak. Blocking the ports in the TB should have killed the engine.
Old Jul 4, 2016 | 06:22 PM
Maw76's Avatar
Thanks for your input . I have tried blocking the air intake that makes the emgine to die. But when I block both the holes in throttle body (iacv & ficv)
Rpm goes to 8000
Maw76's Avatar
800
Old Jul 7, 2016 | 04:09 AM
Muckman's Avatar
Moderator in Chief
Did you adjust the idle air bypass set screw?
Adjusting your idle speed (Gen3) - Team Integra Forums - Team Integra
bdonahue
Mar 21, 2016 08:20 AM
jmacsss
Dec 17, 2011 08:36 AM
psmoss
13
Jul 4, 2008 03:06 PM
88hondacrx
Oct 28, 2006 12:49 PM
klamath
May 11, 2005 10:53 PM
