OBD2A Diagnostic question
Old May 6, 2010 | 07:43 AM
Mr. B16's Avatar
Default OBD2A Diagnostic question
Will the prescence of aftermarket camshafts, High comp pistons, etc affect a stock ecu primarily used for passing obd2 diagnostc tests?
Old May 6, 2010 | 09:25 PM
HAMOTORSPORTS's Avatar
Default Re: OBD2A Diagnostic question
You may get CEL codes for knock (if they are forged pistons) and possibly Crankshaft Position due to the uneven rotation with high lift cams/ loping/ etc..
What kind of diagnostic tests are you referring to?
Old May 7, 2010 | 08:02 AM
Mr. B16's Avatar
Im reffering to the annual inspection tests that post 96 cars have to take, the kind where they plug into the ecu under the dash.
BC_Garage
43
Nov 19, 2011 08:42 PM
Scott53092
21
Oct 2, 2010 11:09 AM
Tyteg
Apr 25, 2007 10:32 AM
01PYITR
Aug 17, 2002 05:32 PM
