Obd1 pr4 vtec add-on?
Old Apr 19, 2010 | 09:37 PM
vtecn8ive's Avatar
Default Obd1 pr4 vtec add-on?
I recently picked up a pr4 automatic ecu from a 92-93 Integra.
I have been reading up on the ecu and I am not 100% what is needed to have it chipped, run 5 speed and enable vtec.
I understand the chipping part and how-to convert to 5 speed.
But I'm confused about the vtec add-on. So in order to have this obd1 vtec 5 speed, I will need to have a chip installed, jumper (for 5spd) AND the vtec add-on?
This is what I was thinking I need for vtec add-on:
http://cgi.ebay.com/ebaymotors/HONDA...item1c0cd139bf
http://www.xenocron.com/vtec-convers...ecu-p-278.html
Would this be the same concept of p06-p28?
I tried to search but I've yet to get the hang of the search engine on this site after the big change.
Old Apr 19, 2010 | 10:06 PM
mtber's Avatar
Default Re: Obd1 pr4 vtec add-on?
You will need a vtec conversion kit: http://www.phearable.net/shoppingcar...ion-p-121.html
You will need a Chip Kit with a vtec basemap for your engine:
http://www.phearable.net/shoppingcar...chip-p-59.html
Old Apr 20, 2010 | 02:31 PM
xenocron's Avatar
Yes same concept as the P06-->P28, as these ECUs all use the same basic board layout and function.
To chip and convert your ECU you would need both a chipping and VTEC kit
http://www.xenocron.com/combo-kit-ch...sion-p-55.html
Old Jun 21, 2010 | 10:43 PM
MrMike's Avatar
I'm in a similar sitiation as the OP but I have a P75 ecu with a Hondata S100 system already installed. I want it to run my lsvtec, so I need to convert it to vtec. Would the vtec conversions u guys sell work for this and all i'd need after that is a vtec map loaded for the Hondata?
SMOOTHN
Jul 5, 2010 11:51 PM
bakoCRX
Oct 20, 2009 01:33 PM
technine
Jan 17, 2008 10:43 AM
Shaun_
17
May 22, 2007 02:49 PM
