launch control problem
Old Apr 2, 2010 | 07:24 AM
noobee's Avatar
Default launch control problem
i've got a question, i've got a msd 3 step launch control attached to msd 7al2. this is how i do my launch..: first i press the clutch, press button, floor the gas and release the clutch and go!
the problem is i will try preloading, so i pre stage, pull the e-brake, release the clutch till i feel like its dipping, release the the e -brake a little bit to stage, then pull e-brake, press the button(for launch control) and floor the gas BUT the rev limiter won't work! sometimes, it works but i can't let the clutch loose to much because it disengages... what seems to be the problem?
i don't have a line lock or anything.. my guess is that the higher i release the clutch pedal the clutch switch disengages therefore disengages the rev limit. how can i fix this?
noobee
Apr 3, 2010 12:34 AM
BJA86
Jul 18, 2007 10:47 AM
88 yellow crx
Jun 12, 2007 12:38 PM
92hatchattack
Apr 6, 2007 07:27 PM
rice is nice
Jun 30, 2005 01:46 PM
