Simple tune for new header?
Old Mar 12, 2010 | 02:50 PM
88Hatchy's Avatar
Default Simple tune for new header?
I currently have a JDM Type-R header on a semi-built B18C. A while ago I purchased a genuine Hytech header. I'm wondering if it is acceptable to just add the necessary fuel to keep it from going lean, as opposed to a full tune with ignition, etc. My my setup is currently tuned, and I would rather wait until I get headwork before I spend the money on a dyno tune.
Old Mar 13, 2010 | 08:30 AM
Top Ramen's Avatar
Default Re: Simple tune for new header?
Clean the plugs, run if or a couple of days then check them to see if you even need to mess with it.
Old Apr 14, 2010 | 05:31 PM
VegasInvasion's Avatar
I'm Huge In Japan
Yeh, it's not likely you'll need to re-tune for that. Although, if it's the anti-reversion header you might try dropping the 5,000+ RPM timing values about 1* and see if you can squeeze a few numbers out (after you adjust the fuel). I've had positive results with that before.
Old Apr 16, 2010 | 03:37 PM
mtber's Avatar
It is highly unlikely that the change in the header is going to result in such a lean condition which causes danger to the engine. You should be ok to wait until you do further modification to have the tune re-done.
Old Apr 16, 2010 | 08:47 PM
richardre's Avatar
i agree with the guys...headers dont make much of a difference and if your going to do a dyno tune i strongly suggest u do as much as u can before u tune it so u only do it once and get the best results out of it.
reg_lus
Dec 14, 2014 06:03 AM
umair
20
May 13, 2009 07:58 PM
louie3252
Mar 24, 2006 10:51 PM
junbb1
May 23, 2004 06:38 PM
TitanMotorsports.com
244
Dec 10, 2003 06:41 PM
