Injector help
Old Mar 25, 2010 | 12:48 PM
titosek4's Avatar
Default Injector help
A friend of mine has a set of obd1 injectors from his h22 and Im wondering if I can run them on my b16a2 96 hatch(ek) that is obd2a
Thanks in advance
Old Mar 25, 2010 | 01:44 PM
lyncoors's Avatar
Default Re: Injector help
just the clips are different
Old Mar 25, 2010 | 02:10 PM
titosek4's Avatar
thanks
Old Mar 25, 2010 | 04:30 PM
1993-eg1's Avatar
u can but I do not know if u will run rich or not due to sizing. but the h22 uses a resistor box and u will need to as well. this will help u with the install there is a wright up that i fallowed as well some where on ht but i know where this one is http://h22squad.proboards.com/index....play&thread=97 . and I will add for other people looking for help later 97+ Prelude VTEC used Saturated Injectors and will not need a resistor box
just found this on injector sizing for your car and the h22 my be off but i thick it will be close i did not thick Saturated Injectors came in the prelude till 97 they say here 96
92-00 D16z6/y8, B16, B18b, B18c1/5, B20b/z - ~245cc, saturated
88-91 D16a1, B16, B18a - ~245cc, Peak and Hold
92-95 H22a, H23 - ~330cc, Peak and Hold
96-00 H22a, H23 - ~290cc, Saturated
here is where this info came from http://www.************.com/forums/s...d.php?t=235495
Old Mar 25, 2010 | 04:38 PM
1993-eg1's Avatar
more help I will be using dsm 450cc Injectors in my project they are all so Peak & Hold Injectors and will need a resistor box. this will give u more on other ways of wiring the resistor box in https://honda-tech.com/forums/forced-induction-16/using-dsm-injectors-691345/
Old Mar 25, 2010 | 06:52 PM
titosek4's Avatar
Thanks for the help guys I'm going to do some more research before I decide
Old Apr 3, 2010 | 06:55 PM
rapidoo15's Avatar
yes you can just differnet clips i think
Crxh22ajdm
Nov 26, 2012 12:42 PM
eruktion
12
Jul 1, 2010 12:24 AM
hwt101
Mar 21, 2009 04:34 PM
AccludePower
Sep 2, 2006 07:01 PM
humble2.0prelude
Feb 11, 2005 04:47 PM
