SFC VTEC controller on a d16z6
Old Mar 26, 2010 | 11:39 AM
wolf95's Avatar
Default SFC VTEC controller on a d16z6
I'm playing wit a field SFC VTEC controller in my 95 honda del Sol Si with a d16z6. we set the buttons on the back to the d15b settings and hooked everything up to the best of our abilities. PROBLEM: the rpms are WAY off and now it's throwin a MAP code. We turned it off until we can figure everything out. I was just wonderin if anyone knows EXACTLY how to hook it up on a z6 and any tips or tricks on tuning it. We are going to the drag strip tonight to play with it but we are just blind tuning at this point. any help would be EXTREMELY appreciated.
O I forgot to say I have a mildly modified z6. INtake, headers, exhaust, Adjustable cam gear set to 0 and a FPR that's set to 30 psi.
Old Mar 26, 2010 | 01:23 PM
mtber's Avatar
Default Re: SFC VTEC controller on a d16z6
You can't just hookup an afc and start messing with settings.
You need to tune it using a wideband oxygen sensor gauge to monitor air fuel ratios.
Concerning the code you are throwing, it sounds like you improperly installed the unit.
Old Mar 26, 2010 | 01:25 PM
wolf95's Avatar
my friend had it on his prelude and he said we can play with it. that's the only reason I'm playin with it. All the wires are correct but I will double check.
and where can I get a wideband o2 sensor gauge?
Old Mar 26, 2010 | 01:38 PM
wolf95's Avatar
lemme correct myself... where can I find one that's NOT 400 bucks
Old Mar 27, 2010 | 06:12 AM
wolf95's Avatar
nvm I found a few. but has anyone played with these? I'd like to learn of any personal experiences
LUiS010606
Mar 22, 2011 08:58 AM
jfrase06
May 19, 2007 07:04 PM
zx2gotboost
Feb 13, 2006 02:12 PM
asnx6pac
Oct 22, 2001 07:01 AM
max
Aug 7, 2001 09:00 PM
