TUNING FOR OBD0??
Old May 16, 2010 | 08:14 PM
rudyndrew's Avatar
Default TUNING FOR OBD0??
Just want to know if theres a tuning system for obd0. I'm on a budget in a way, and since my cars obd0 ill just keep this way. im running a b16a with a built head and ctr pistons and all the bolt ons so any1 out there know of any systems?
Old May 17, 2010 | 07:31 AM
craig88crx's Avatar
Default Re: TUNING FOR OBD0??
there is one program that my friend ben ogle made that has worked well for some people its called BRE.
Old May 17, 2010 | 10:47 AM
THC07's Avatar
dude get a budget then. you will not have fun messin with the BRE editor.
save up and go obd1. obd0 tuning is obsolete
Old May 17, 2010 | 12:15 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
since we are all running on microcontrollers that were popular back in the late 80's...technically, obd1 is obsolete also.
to answer the original question, for obd0 (nonvtec) ecus your best bet is to use turboedit, bre (both require the use of development roms from pgmfi) or zdyne.
for obd0 vtec ecus, your best bet is to use bre...
Old Jun 9, 2010 | 03:21 PM
OXY95LSSC's Avatar
from what I hear this is true. there are many ppl I have spoke with in europe who have pretty much full access to all the jdm cars & also had the euro version of the ef8/9 the 1.6VT. All of them run a PW0 tuned on BRE. Even if you were to do say a 98spec ITR swap as long as its NA no need to go OBD1/2. You can run OBD0 & it will cope. consider the wiring, ECU, dizzy and injector type (ie: running a resistor box or not). BRE will happily support 450cc injectors or higher too. I think it even has ITB support now too.
You go turbo for sure convert to OBD1.
Im staying OBD0 w/ my b16a
Old Feb 8, 2014 | 11:58 AM
gabrielsousa's Avatar
where i can download BRE ?
Old Feb 8, 2014 | 03:33 PM
xenocron's Avatar
Google it "Ben ogle's rom editor"
Old Feb 8, 2014 | 03:34 PM
thanks a lot, what eeprom is ?
Old Feb 11, 2014 | 02:57 PM
VegasInvasion's Avatar
I'm Huge In Japan
you need to be able to access the PGMFI forums and read it THOROUGHLY. all of these questions and many more have already been answered on the forums. start a new account if you have to.
Old Feb 11, 2014 | 07:33 PM
1988integra's Avatar
You can download a BRE from ef-honda. google that too.
Old Feb 12, 2014 | 02:55 AM
Freemananana's Avatar
Bre is alright from my experience. It does support boost tables and fuel/ignition maps. Would be hard to tune for anything but AFRs on the street with BRE. So don't expect to make a lot of power. You'll also need either a chip burner or an emulator.
kraquepype
Apr 18, 2018 01:39 PM
ef panda
Feb 11, 2013 06:03 PM
CRXBOI239
Sep 5, 2010 10:22 AM
blaak-crx
11
Sep 10, 2009 11:51 AM
turbotime
Mar 28, 2006 03:29 PM
