OBDII inspection problems HELP
Old Mar 30, 2010 | 11:58 AM
jmicus123's Avatar
Default OBDII inspection problems HELP
okay i have a 2000 civic si.
the block is a b18c with my si head.1000cc precision injectors. 9.1 cp pistons, bored to 84mm. stock head with ctr cams and ts got a 35r on it.
Im running a p28 obd1 ecu with neptune rtp
the car isnt running yet but it will be in about a month and im going to need a sticker. What can i do? I know the vins need to match the car. Is it possible to swap my si obd2 ecu back into the car and run it for inspection with the stock injectors and the stock o2 sensor. Will that work or am I in for a world of ****.
any suggestions.
Old Mar 30, 2010 | 08:14 PM
mtber's Avatar
Default Re: OBDII inspection problems HELP
Talk to some local dyno tuning shops for a solution.
They may have some ideas on ways to get a sticker depending on regulations in your state.
Old Mar 31, 2010 | 05:02 AM
Honda_Kid12's Avatar
TRIAL USER
I bit the bullet and bought this thing and it worked flawlessly:
I got it from a guy on pgmfi.org and he sells them on his website now apparently.
Check out my earlier post:
https://honda-tech.com/forums/engine-management-tuning-124/obd-ii-emissions-idea-2607274/
Old Mar 31, 2010 | 07:33 AM
jmicus123's Avatar
so that worked? damn, why havent i heard of this before
Old Mar 31, 2010 | 07:41 AM
HRTuning's Avatar
It's fairly new to the market, that's why.
www.immensehardware.com
You'll need the ISO version. $149
Old Mar 31, 2010 | 08:05 PM
redline_z6's Avatar
anyone know how to disable the anti-theft system in a 99 civic si so i can run a 01 gsr ecu. obd2b gsr in my car
Hahnsolo85
Apr 27, 2013 08:30 PM
b16bri
Jun 30, 2010 08:10 PM
TheDohcside44
Jul 26, 2009 08:02 PM
Shaynepolevault
Oct 7, 2008 10:06 AM
