P06 O2 sensor ground
Old Mar 24, 2010 | 05:41 PM
grandtheftlunchbox's Avatar
Default P06 O2 sensor ground
Okay, so I want to use my Zeitronix wideband's narrowband sensor output to replace my age-old stock O2 sensor. The thing is, it's a 4-wire sensor, and the narrowband output on the wideband controller only supplys the input signal for the ECU, not the ground or the heater control. So, how should I go about doing this? I can take care of the heater issue with a resistor, but will the ECU throw a code if I don't supply a ground?
Old Mar 24, 2010 | 07:55 PM
Relic1's Avatar
Default Re: P06 O2 sensor ground
the ground is common with the power ground. as long as the output shows 0-1V it will be fine.
If you're tuning disable the O2 heater, no need for the resistor.
Old Mar 25, 2010 | 04:02 AM
Alright, that's kinda what I suspected but wanted to clarify. I was also going to disable the O2 heater but i wasn't sure whether it would still throw a code if i just disconnected it. thanks
jdm89crxhf
May 18, 2013 02:26 PM
slow96lude
Oct 15, 2009 05:07 PM
JoshJosephKeith
May 4, 2009 04:38 PM
jonrv13
Sep 20, 2007 08:04 AM
draxxus07
Oct 13, 2005 05:41 PM
