obd0 to obd1 help
Old May 5, 2010 | 07:56 AM
craig88crx's Avatar
Default obd0 to obd1 help
i am changing my 88crx from obd0 to obd1. so i can tune my turboed b16. got the conversion harness and woundering if i need 2 o2 sensors one for my wideband and one for my p28 with hondata s300. or if there is some way i can wire my wide band into my ecu so it data logs it too. i have and older teWBo2A. hope im making some sence or not to dump of a question just want to make sure i have everything right.
Old May 5, 2010 | 08:19 AM
mtber's Avatar
Default Re: obd0 to obd1 help
You do not have to use any narrowband o2 feedback if you do not want to.
90% of our customers do not run narrowband o2 feedback, only wideband 0-5 volt feedback into an input on the ecu.
Old May 5, 2010 | 09:29 AM
craig88crx's Avatar
so your saying i dont need to use my wideband. sorry kind of confused
Old May 5, 2010 | 06:56 PM
PyroProblem's Avatar
Keep the wideband. Ditch the narrowband. You can setup the wideband to work with your (tunable/chipped) ecu.
Hope that helps!
Old May 5, 2010 | 08:48 PM
craig88crx's Avatar
Ya helps just don't know how to wire my tewbo2a into my p28 ecu that has hondata s300
Old May 6, 2010 | 04:05 PM
Not familiar with the Hondata software, but either way you probably need to wire the output from the wideband to the o2 sensor input at the ecu. (D14 I think it is on a P28?). Then configure it in the hondata software and you should be good to go...
At least this is how it is with Neptune..
Old May 7, 2010 | 01:54 PM
craig88crx's Avatar
ya thats what i wanna do is run the wideband into the ecu so i camn data log it and so my hondata can see it too. but just not sure how to wire it in
Old May 7, 2010 | 02:06 PM
craig88crx's Avatar
Old May 15, 2010 | 09:39 AM
SLOSI7's Avatar
i have the same ecu setup. and theres a few diferent places you can wire it in at but i decided to wire it into the edl. im assuming you dont know wat that is but its the medium size plug in the ecu and its the 5th one from the left on the bottom.
http://www.hondata.com/help/smanager/index.html
open that link and open the reference book and click on ecu conectors that should show you better then i can explain.
also ive heard that in some ecu's when you use the edl location you need to cut out 2 of the resistors from inside, they are r136 and r138. they are all numbered inside so go ahead and do that, its recomended by hondata for some ecu's
hope that helps
crxb16a90
May 6, 2016 11:19 AM
Treyschls
Dec 11, 2014 07:49 PM
Will Albers
Mar 12, 2009 11:20 AM
escourt23
16
Dec 4, 2005 02:22 PM
B16CRXT
Jan 24, 2004 07:16 PM
