Is my wiring right? Using diff. O2 sensor, getting CEL
Old May 9, 2010 | 03:56 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Is my wiring right? Using diff. O2 sensor, getting CEL
So after 230k, I figured my o2 sensor could stand to be replaced. A buddy of mine had a couple random 4 wires laying around, so I found a wiring diagram online and wired them up. I've always heard that 4 wire o2s are universal, so I figured it'd be worth a shot. Here's the diagram I used:
http://home.earthlink.net/~jcgebhart/o2sens.html
I've tried both the sensors, and gotten an o2 cel as soon as i start it up. I want to know if I've wired it up wrong, if these just flat out can't be used with the ecu, or if the sensors are bad (they both seem fairly new). This is in a pretty much stock 92 gsr.
The Sensors:
I pulled out a stock nippondenso 063500-8310, and tried to use a denso 12567254, which comes back as a gm part. The other one I tried to use was a toyota/denso 89465-34150
stock was:
white - signal +
green - signal -
black - heater
black - heater
both of the other two were:
blue - signal +
white - signal -
black - heater
black - heater
So I did white to blue, green to white, and blacks to blacks. Did I do something wrong?
Old May 10, 2010 | 03:18 AM
Default Re: Is my wiring right? Using diff. O2 sensor, getting CEL
Im getting codes 14 and 41. O2 heater malfunction, and IAC valve malfunction. Anyone? Could the black wires be bad, or do i need a different sensor?
Old May 11, 2010 | 07:15 PM
Hmm, according to this, code 14 can be either the idle air control valve or a bad ECM.
http://check-engine-light-codes.blog...retrieval.html
Pulled the IACV, looks like it might be stuck open? Anyone know for sure? I suppose I could put some voltage to it and see if I hear it click...
OoAoO
Jun 27, 2011 10:09 PM
exotik4doorcivic
Dec 18, 2007 03:55 AM
patastinky
Jul 19, 2005 01:24 PM
done
Jun 20, 2004 02:36 PM
