Is there a way to fix this!!!!
Old May 15, 2010 | 02:14 PM
crob621's Avatar
Default Is there a way to fix this!!!!
Like the title says i broke a pin in the USB conector for my S300 everything works fine i just can use the laptop it wont read... i know I can send it to hondata but i don't have the money for that now.... i tryed to bend it back down but it broke now it's not long enought to have contact with the other part
Old May 15, 2010 | 02:31 PM
GhostAccord's Avatar
Default Re: Is there a way to fix this!!!!
If you know how to solder you could easily replace the USB connector on the circuit board. Digikey part number A98573-ND would probably work. they are $1.66 each.
Old May 15, 2010 | 02:41 PM
crob621's Avatar
oh wow $1.66 is way better than $250 thanks man ill look into this
Old May 15, 2010 | 03:29 PM
crob621's Avatar
is their a write-up out there about doin this. Ive been lookin but cant find anything
Old May 15, 2010 | 04:54 PM
I doubt there is a write up. I have done many of these sorts of repairs. I could probably do a sort of walk through for you. First things first. How comfortable are you with soldering tools?
If you are not comfortable with de-soldering and soldering circuit board components. I would suggest that you take it to a TV repair shop and see if they can do it for you. Should only take them 30 min to an hour max for labour.
k20z1kid
Apr 3, 2008 10:28 AM
drive4aliving
Dec 8, 2003 08:16 PM
Seann
Apr 15, 2003 09:14 PM
E Swift
Sep 10, 2002 07:54 PM
JAMinCiViC
Jan 22, 2002 07:52 AM
