base map vs stock map?
Old Mar 18, 2010 | 08:50 PM
Sr420Det's Avatar
Default base map vs stock map?
Ok, say i ordered a jdm d15b had the option to get the factory ecu for another 125. Would it b better to get that or order a chipped ecu with a "stock base map". Of course I would want a functional o2, 8k rev limiter, 4k vtec, no speed limiter.
Can a person chip a ecu and fully replicate a stock ecu? Same ign and fuel tables?
Old Mar 18, 2010 | 10:26 PM
Sr420Det's Avatar
Default Re: base map vs stock map?
help a newb out. I was told u could not replicate a stock ecu
Old Mar 18, 2010 | 10:34 PM
GhostAccord's Avatar
Not 100% sure about that. I chipped a P06, downloaded and burnt a stock F22B2 basemap onto the chip without any problems. I was able to datalog and I also had a wide band O2. The AFR's were pretty much bang on. I checked my plugs every other day for signs of detonation or fouling and they remained relatively clean.
Now to trust a base map without some way of monitoring it's processes would be a bit sketchy.
Are you planning to do any further modifications to the engine? If your just going to run it stock/maybe some bolt-ons. I would go for the stock ECU.
Old Mar 18, 2010 | 10:49 PM
Sr420Det's Avatar
Yeah its for a buddy of mine and weve already purchased the chipped ecu for 110. He doesnt have a tach so I wanted the shift cel and it feels better with vtec a lil lower on the d-series. I also want to add a nitrous wet kit on later (ran my b16 w/chipped ecu and a 75 shot for a year) but i want to b sure the ign timing is stock. Im not real worried the jetting recomendations r completely conservative but its just for peace of mind. The guy chipping it was highly recommended but he told me he could not copy a factory ecu so he gave me one of a tune he did with the parameters i requested. This motor does have intake mani, tb, exhaust, etc..
It just baffled me, i thought for sure u could copy stock maps. I always thought I was safe with running a "stock base map" (granted from a reputable person or company) and assuming all fuel and ign tables were stock so i could work from there
Old Mar 21, 2010 | 09:50 PM
Top Ramen's Avatar
You can get very, very close. Try these guys: http://www.phearable.net/
aggressivecivic
Jan 22, 2008 05:52 PM
AZNracerx1989
Jan 16, 2006 07:41 PM
Stingray96
Nov 1, 2005 09:20 AM
teg92
19
Jan 20, 2005 01:09 PM
