Boost control
Old Mar 3, 2010 | 03:22 AM
JDM97R's Avatar
Icon2 Boost control
Hi to everyone,
I have an Aem boost solenoid wired in my Civic with an S300.
I am trying to use the boost by gear , but nothing seems to work.
So I was thinking ( if it is possible ) to make a switch on the 12v of the solenoid and on my 1st gear and 2nd gear I turn the solenoid off so I use the wastegate spring and then in 3rd gear I put back the 12v on the solenoid and I will have the boost that I ve set in the S300.
Can it be done or just a waste of time?
Thanks
Old Mar 3, 2010 | 06:18 AM
92TypeR's Avatar
FSAE
Default Re: Boost control
Be patient and get the S300 PWM to work.
Make sure the polarity of the solenoid is correct. You will need to 'tune' the PWM tables before boost by gear works.
Try the Hondata forums.
Old Mar 3, 2010 | 06:24 AM
JDM97R's Avatar
I checked also on Hondata forum but I can t make it work
All the time I set the boost on the ecu and when i try the car neither the boost stays low nor I have a boost cut
Don t know what to do
The Races are 3 weeks from today and last time I was at the strip I did 10.0@151 with the first two gears spinning all the way
I wish I can work something
s2kseven
Apr 24, 2018 09:11 AM
JDM97R
Mar 4, 2010 04:43 AM
JDM97R
Mar 3, 2010 06:19 AM
purpleh22
Oct 18, 2009 01:34 PM
turbo_b16_ex
May 7, 2006 02:48 PM
