Stock ecu vs base map for dyno...
Old Apr 23, 2010 | 06:51 AM
Damaged Goods's Avatar
Default Stock ecu vs base map for dyno...
Hey guys..
I'm finally about to do some type of upgrade on my car which is to buy an s300, but I haven't done a base run yet on my current set up. I was originally planning on doing a base run with my p73 and than once I get my s300 tuned I could do another run to compare the differences. I know the difference would be small, but I would just like to know exactly where I was before. My mechanic told me that I should just install the s300 and I could do a base run dyno with a base map and then tune and re-dyno.
First question is should I go with my original idea? Second question is worst case scenario if I get a base map added to my ecu how long could I drive that around for?
I apologize if this is wordy or doesn't make complete sense, for I did another all nighter last night typing a paper for class.
Thanks for all your help in advance.
Old Apr 23, 2010 | 07:28 AM
mtber's Avatar
Default Re: Stock ecu vs base map for dyno...
Instead of renting the dyno twice, simply go to the dyno & make a run on the stock ecu, then install the s300 & tune it to compare etc.
Old Apr 24, 2010 | 08:54 PM
Awesome sir thank you.
enemy no1
Engine Management and Tuning
Jan 12, 2011 10:02 AM
adam00
Jan 26, 2009 09:19 PM
gofastcrx
Dec 28, 2006 08:13 AM
ProjectLSVTEG
Dec 4, 2005 07:11 PM
