Idle problem on modified H22
Old Apr 28, 2010 | 01:43 AM
pentaq's Avatar
Default Idle problem on modified H22
Here it is:
H22 with Mahle 11.5:1 pistons, Eagle rods
Omni Power TB WITHOUT FITV and idle setting screw
Double stack Blaktrax modified intake manifold
450cc injectors
Tuned on Crome
Skunk2 stg. 2 Pro cams
Idle is set on 1200rpms, IAC duty cycle is almost 100% and still cannot maintain idle. Any additional load on the engine (AC, lights etc.) is stalling it. Sometimes IAC triggers CEL (which is quite undestandable as it's going out of range).
How can I force the engine to run properly and compensate additional load as it is done on unmodified car? Different IAC (which then)?
Thanks
Old Apr 29, 2010 | 03:38 PM
q16racer's Avatar
Default Re: Idle problem on modified H22
what is your base timing?
________
RS200
Old Apr 30, 2010 | 02:10 AM
pentaq's Avatar
16degrees
Old May 1, 2010 | 01:38 PM
q16racer's Avatar
add more timing at idle
________
YAMAHA CS-80 HISTORY
cfoland
Feb 18, 2011 07:57 PM
twiztid00002
Jan 23, 2009 05:26 PM
UK_Luder
Jul 24, 2007 09:08 AM
dek1mfk
Nov 20, 2006 02:56 PM
jdmjonnyacc
Apr 26, 2006 10:13 PM
