i have an easy question
Old May 15, 2010 | 10:45 AM
EF-ingB16's Avatar
Default i have an easy question
my ecu is flashing a code and im not sure what it means. it flashes one long flash then 7 short flashes. im kinda new so im not sure.
any help would be great.
thx
Old May 15, 2010 | 12:09 PM
GhostAccord's Avatar
Default Re: i have an easy question
That would be a code 17. That indicates a problem with the vehicle speed sensor circuit (VSS)
Old May 16, 2010 | 11:54 AM
EF-ingB16's Avatar
hey thanks. my speedometer doesnt work could that be why im getting that code?
Old May 16, 2010 | 12:44 PM
No. I would say that your speedometer doesn't work becuase the VSS isn't working and that is why your getting the code. It's ether disconnected/corroded wires or no longer working properly.
Old May 18, 2010 | 10:47 AM
EF-ingB16's Avatar
ok thanks Ghostaccord for the info. do you think this is something i could figure out myself or should i take it somewhere? im not realy sure where to start so any more info you could give me would be greatly appreciated.
Old May 18, 2010 | 06:35 PM
What year is your Accord?
If you have an Accord manual and a multimeter it should be easy enough.
Old May 19, 2010 | 11:35 AM
EF-ingB16's Avatar
i accualy dont have an accord i have a 90 civic Si with a b16a obd 0.
thanks for trying to help me.
Old May 19, 2010 | 01:52 PM
My bad... I'm so used to answering in the Accord forum.
Same goes for the Civic though. You should be able to find a free pdf of the Honda shop manual online for the older Civic.
Old May 20, 2010 | 10:32 AM
EF-ingB16's Avatar
ok ghostaccord, thanks for the info and the time you took to help me.
tcyman2718
Jun 3, 2015 10:15 AM
Navy_Engineer
May 2, 2013 09:21 PM
GnatBee
Sep 1, 2012 11:04 AM
beedees
Aug 16, 2009 02:28 PM
