PC does not see the ECU HELP!! Please
Old Apr 28, 2010 | 06:31 AM
codine's Avatar
Icon2 PC does not see the ECU HELP!! Please
For starters i need to know if its going to work
i got a usb cable and a ttl to usb adapter i cut the ends off put a for prong deal on the end that that would connect to the ECU prong i got soldered on and cut off j12 i got the drivers for the ttl to usb and it seems to be working but it just does not see the ECU. what do i need to do
ECU Side
1: Black
2: Red
3: None
4: White
5: None
am i going to have to hook up the 5v or 3v wire.
Help Please.
Old Apr 28, 2010 | 06:50 AM
codine's Avatar
Default Re: PC does not see the ECU HELP!! Please
Sorry about that i have a 95 Civic with a B18C1 DOHC Vtech It's got a P06 but it was converted and chipped am i going to have to do something else to make the Datalog work
I hope i got the correct chip. here it is.
__________________________________________________ ________________________
Built-in USB to RS232 Transfer chip.
Designed to be used for USB to TTL electronic applications.
TTL interface output, easy to connect to your MCU.
Power LED.
STA LED.
Dual 3.3V and 5V Power output, work with both 3.3v and 5v target devices.
Compact design.
Dimension: 40mmx15mm.
High Quality
Old Apr 28, 2010 | 07:54 AM
HRTuning's Avatar
You don't need to hookup power at all, notice it says power output for target devices... The ECU already has power at CN2 and this device is powered by USB. What you do need to do is make sure the drivers are installed.
CN2 does not have the same pinouts as this device. You will need to switch the wires.
1: GND
2: RX (Data from the PC to the ECU)
3: +5 - No connection needed
4: TX (Data from ECU to the PC)
5: N.C. (not connected)
Old Apr 28, 2010 | 08:06 AM
codine's Avatar
Thanks im going to try that now i will be on here in an hour to let you know if it worked.
Thanks
Cody.
Old Apr 29, 2010 | 06:51 AM
codine's Avatar
I got it to work but it doesnt change it shows up vtech on ecucontrols but with the key on it shows 940 RPM, and when starts it doesnt show any change.
the com port is set to 38400 and so is the ecucontrols is there anything else i need to change? and on crome it does not loop back.
not sure what i need to do i am just setting it up for the gauges not so much to datalog.
HELP..lol...Please
Thanks.
Old Apr 29, 2010 | 10:11 AM
GhostAccord's Avatar
What version of Crome are you using? If your using the free version of Crome you will not be able to datalog.
What gauges are you trying to set up?
Old Apr 30, 2010 | 06:35 AM
codine's Avatar
I'm not sure what version i have. but i just want gauges on the screen..lol..
What would be the best software to use for gauges on the pc screen?? i have a 10 inch screen in my dash...Thanks for the help...
Cody.
Old Apr 30, 2010 | 06:46 PM
MrDomino's Avatar
Cody.
You have to pay $150 to datalog with Crome.
Old May 3, 2010 | 07:53 AM
codine's Avatar
I have a Skunk2 chip, XS chip and some other chip with nothing on it.
can you datalog with Skunk2 or the other chips i have???
somebody told me i can't datalog with Skunk2 chip...
Thanks
Cody.
Old May 3, 2010 | 07:55 AM
HRTuning's Avatar
The programs you're trying to use don't datalog the stock protocol.
Old May 3, 2010 | 11:51 AM
codine's Avatar
Icon2 Re: PC does not see the ECU HELP!! Please
What program do i need??
Old May 3, 2010 | 11:59 AM
HRTuning's Avatar
If you're absolute on staying with what you have this is the only one I know of that is public and supports the stock protocol.
http://www.doctronic.at/HondaComm_E.htm
Otherwise you'd be better off getting a map made in several of the tuning options available and using their respective datalogging software.
apexrift
Engine Management and Tuning
Oct 22, 2009 07:29 AM
KARSON
Mar 4, 2009 04:16 PM
Littlegreend15
Jul 16, 2005 04:51 AM
alfaaay
Apr 7, 2004 12:20 AM
