Which ECU?
Old Mar 3, 2010 | 02:43 PM
hondatuner020's Avatar
Default Which ECU?
i am running a 97 integra gsr, which is obd2a.... i plan on buying neptune rtp demon
if you look at the ecu options on this site
http://www.xenocron.com/neptunertp-d...new-p-223.html
can i use the obd1 vtec ecu with adapter harness to obd2a? or do i have to use a p72 to match my motor?
Old Mar 3, 2010 | 02:51 PM
HRTuning's Avatar
Default Re: Which ECU?
The OBD1 VTEC ECU will work just fine, but you'll lose IAB control unless you ask specifically to have that added.
Old Mar 3, 2010 | 03:08 PM
93turbo16's Avatar
The IAB circuitry can be added fairly easily to most of the OBD1 Civic ECUs. I am sure if you request it when you ordered it can be taken care of for you.
Old Mar 3, 2010 | 03:09 PM
HRTuning's Avatar
Be sure to mention your engine's year, too, as OBD2 is done differently.
Old Mar 4, 2010 | 10:22 AM
xenocron's Avatar
I do them if requested, but I only do OBD1 Style...thus why I made this write-up a while back
http://www.xenocron.com/install/OBD1-IABs.htm
Old Mar 4, 2010 | 10:25 AM
HRTuning's Avatar
Good to know, that's why I asked him to mention just in case.
Old Mar 4, 2010 | 03:32 PM
if i do not have iab then what happens? also does the p28 or p72 have it?
i also plan on running a blox intake mani and tb aswell
Old Mar 4, 2010 | 03:50 PM
HRTuning's Avatar
If you don't use IAB, simply disconnect the vacuum line from the actuator and plug the line so it remains open and have it tuned properly in that configuration. You'll lose some low range torque, but not much. It will still run perfectly.
If you're going to switch intake manifolds you don't need the IAB output anyway, so no worries.
You can add it to P28, and xenocron will as he mentioned. P72 has it from the factory.
Check the link xenocron posted on how to set it up for OBD2.
frankiecutz
Engine Management and Tuning
Oct 4, 2010 01:15 PM
Ek9_Cuhzz
Northwest (Sales)
Jul 15, 2010 12:07 PM
Jap_Spec_Imports
Aug 10, 2009 07:11 PM
dsmh8tr
Aug 27, 2008 07:13 PM
2.2 teg
Oct 20, 2005 08:21 AM
