Pro1 Idling help!
Old Mar 25, 2010 | 07:10 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Pro1 Idling help!
Hey guys.
Last summer I got together a turbo setup and have been slowly piecing together the turbo kit for it. In the meantime I am still driving the car for fun.
LsVtec, 10:1cmp, Pro 1's, S300.
I am trying to drive it more and more so I am trying to fix minor issues. My last one to get through is getting this thing to idle on cold starts.
I have a current map on Hondata.com, I have made a few changes to the fuel trim since I just put a Victor X on but it's still close enough.
I am seeking help with getting this to idle, any help will be appreciated.
I still need to adjust post start fuel trim and cranking fuel trim too.
http://hondata.com/forum/viewtopic.php?t=10948
Old Mar 26, 2010 | 07:02 PM
Natural Aspirations's Avatar
Default Re: Pro1 Idling help!
Are these authentic S2 cams? Blox cams have this problem and there is no real fix.
Cam gear settings?
Set your dist timing?
PM me your email address
Old Mar 26, 2010 | 07:05 PM
93turbo16's Avatar
I have the Blox P1 cams and have no such issues.
It definitely is somewhere in the tune or in the IACV settings/FITV if you have one.
How does the car idle once it is warmed up?
Also what throttle body are you running, OEM casting throttle bodies will always produce the nicest idle and easiest startup.
Old Mar 26, 2010 | 07:30 PM
Good to know Jon, must be a dirty H-T rumor
Old Mar 27, 2010 | 05:03 AM
93turbo16's Avatar
Yea, I have them on my 84.5mm ls/vtec and my good friend has a set on his stock bore B16 and both have stock casting throttle bodies and are tuned with nepTune and idle perfectly.
It is generally the tune (IACV duty, timing, etc) and/or throttle body/intake manifold combination that will cause a car to not want to idle.
Old Mar 27, 2010 | 03:18 PM
Mattb16teg's Avatar
Community Builder
Cam gear settings?
They are the BLox P-1's.
Will Pm you me email address...
Honestly cannot remember what the cam gear settings are, had my buddy help me degree them, will have to look once I get back home. Think maybe 0 or +1 on each.
Link to map is in the OP
Hey John, met you a few times
Will be at the Dyno day!
Once its warmed up it idles perfectly no issues at all!
I had a BDL tb on it and just switched to a skunk 2 when I put my Victor X on. Even with the BDL and an AEBS manifold it exhibited the same startup issues.
I even tried playing with the post start fuel trim and cranking fuel trim too to no luck.
Old Mar 28, 2010 | 03:39 PM
93turbo16's Avatar
If you have the car at dyno day I could take a look at the cal if you would like.
Old Mar 28, 2010 | 04:34 PM
TEAM ASSASSIN SI's Avatar
seems like you to rich at idle.
Old Mar 28, 2010 | 07:01 PM
Mattb16teg's Avatar
Community Builder
Bump, thanks Jon!
Does anyone have a Pro1 Map they could share?
Old Apr 6, 2010 | 06:36 PM
Mattb16teg's Avatar
Community Builder
Bump for some help.
John, I was mad I didn't make it out there. Still willing to lend a hand?
Old Apr 6, 2010 | 07:28 PM
93turbo16's Avatar
Bump for some help.
Of course. Shoot me a pm.
Old Apr 7, 2010 | 06:23 AM
Mattb16teg's Avatar
Community Builder
Great, Pm'd sir!
codyw
Feb 1, 2009 08:52 PM
lsvtec_hatchback
Sep 26, 2006 05:52 PM
LOWNSLOW
May 24, 2004 08:54 AM
HX_Guy
Jun 13, 2002 09:52 AM
bananacruzier
Apr 10, 2002 08:39 AM
