Problem With Neptune
Old May 4, 2010 | 02:38 PM
mouab18c1's Avatar
Icon2 Problem With Neptune
Alright so I hooked up everything, made a basemap but when I start my car it throws a CEL and idles at 2000rpm. I havent jumped the ecu yet but through Neptune Code errors nothing is showing up. Anyone have this issue before?
Old May 4, 2010 | 02:52 PM
HRTuning's Avatar
Default Re: Problem With Neptune
Are you actually able to datalog real-time values?
Check that Injector Test and Knock have been disabled if your ECU does not use them.
Should have posted this on the NepTune forum for a quicker response.
Old May 4, 2010 | 05:58 PM
mouab18c1's Avatar
I disabled my knock sensor but no i am not able to datalog yet. I was searching for forums about it but havent came across anything. I was on hrtuning but i forgot which site it is I made an account that had alot of info about Neptune. But good thing you came around...ahaha with your sigs
Old May 4, 2010 | 06:30 PM
93turbo16's Avatar
It sounds like either you do not have the Demon/RTP setup correctly in the ecu.
Does the ecu run ok on a chip?
Can you verify that you have your 4 pin connector installed the correct way at the CN2 port on your ECU?
Have you gone through all of the help sections in the software... there is a HUGE help database on the Hrtuning.com site and built into the program itself.
I would suggest doing the things mentioned above and definitely reading the help/watching the videos!!
Old May 5, 2010 | 11:02 AM
mouab18c1's Avatar
I got it to work, its just that now my AFR is all funky.
Old May 5, 2010 | 02:42 PM
mouab18c1's Avatar
Got it figured out. Thanks guys
Old May 5, 2010 | 03:04 PM
HRTuning's Avatar
Awesome. :D
Old May 5, 2010 | 03:05 PM
alpha's Avatar
So it wasn't an issue with Neptune? Thread title is very misleading. I can't remember having ANY issues with Neptune to date
Old May 5, 2010 | 06:15 PM
mouab18c1's Avatar
It was, hardware issue and software issue.
Old May 5, 2010 | 09:19 PM
HRTuning's Avatar
I'm very glad you got it figured out. You're welcome to send me a message or email explaining how it was hardware or software related so I know for the future, but it seems highly unlikely at this point with several thousand people running without a hitch up until this point. Thanks, I appreciate your time and always look to improve the NepTune product.
Old May 6, 2010 | 09:32 AM
mouab18c1's Avatar
Yeah thanks for all your help. Some of it was just brain farts. And while installing the 28 pin onto the demon. It was just a little frightening since everything is so fragile. It might be helpful to say that it will take a little force to get the 28 pins onto the demon because it took me 10 minutes trying to push them in without doing any damage. LOL but its all good now. Thanks again
Old May 6, 2010 | 11:30 AM
HRTuning's Avatar
When installing the pins onto the Demon itself? or inserting the Demon into the ECU socket? How forceful you need to be will depend on what type of socket you have in the ECU.
No problem.
Old May 6, 2010 | 02:17 PM
mouab18c1's Avatar
No problem.
The pins onto the demon. When installing the demon into the ecu it was simple. But with the pins onto the demon, I had to push one end down and slowly move towards the other end. Guess it was just me. I didnt think it would need that much force to get it in there.
Old May 6, 2010 | 02:50 PM
HRTuning's Avatar
I see. It's just a socket on the Demon as well, there's just nothing attached to offer leverage.
Old May 6, 2010 | 06:01 PM
mouab18c1's Avatar
Yeah but its all good now. Im loving Neptune
Old May 6, 2010 | 06:16 PM
HRTuning's Avatar
Awesome. :D Let me know if you need help with anything else.
Time to update your signature.
Old May 7, 2010 | 01:04 PM
mouab18c1's Avatar
Sig Updated
Old May 7, 2010 | 01:39 PM
HRTuning's Avatar
wade9233
Jun 26, 2013 01:25 PM
Kangolbrand
Aug 23, 2006 09:23 PM
trinitycivic93
Jul 27, 2005 02:33 PM
hybrider
Feb 21, 2003 09:50 PM
Thagreybomber
Sep 9, 2002 07:17 AM
